'87 R65 instrument cluster wiring
Re: '87 R65 instrument cluster wiring
Postby Rob Frankhamr » Fri Jun 26, 2020 10:44 am
It sounds a little like the connections between the ignition switch and the lighting switches/relays has become mixed up or one of the switches/relays is faulty. Can I ask for a bit more information. The headlight has three seperate filaments in two bulbs... The main beam and the dipped beam in the main H4 bulb and a seperate sidelight (or marker light) bulb. The sidelight bulb also doubles as the parking light. These are the terms used in the UK, you may have different terms...
1) When you refer to the 'headlight' which filament(s) are you referring to? When the headlamp main or dipped beam are on, is the sidelight also on?
2) Is the rear light on when the headlamp is on?
3) Are the instrument lights on when the headlight is on?
The situation should be (assuming a US spec machine) as follows:
a) ignition switch off = no lights
b) Ignition switch to first position - Parking lights - Sidelight bulb and rear light on, instrument lights also on (but not warning lights)
c) Ignition switch to second position - Ignition on - Dip switch to dipped beam - Sidelight bulb, headlamp dipped beam (except when the starter button is pressed), rear light on, instrument light on (any applicable warning lamps on).
d) Ignition switch to second position - Ignition on - Dip switch to main beam - Sidelight bulb, headlamp main beam (except when the starter button is pressed), rear light on, instrument light on (any applicable warning lamps on).
e) Ignition switch to second position - Ignition on - Dip switch to flash - Sidelight bulb, headlamp main beam, rear light on, instrument light on (any applicable warning lamps on).
It is well worth bearing in mind that
i) The 'flash' circuit to the main beam is on a different supply from the 'steady' main beam circuit. This harks back to the euro spec machines with a lights on/off switch where the flash is required to work even when the light switch is set to off. This means that the headlamp working on 'flash' is no guarantee that the main beam circuit is in order (just that the filament works).
ii) Sidelight. rear light and instrument lights are all on the same circuit so when one is on, all should be on.
iii) Headlights are not on a fused circuit but sidelight, rear light and instrument lamps are.
Hope that's of some assistance... If you can come back with the information at the top, I'll try to work out what's going on.
r75boxer
Postby r75boxer » Fri Jun 26, 2020 1:59 pm
Thanks Rob. I am assuming that by side bulb you are referring to the little bulb below the main bulb.
1) When you refer to the 'headlight' which filament(s) are you referring to? The large bulb does not come on unless 'flash' is depressed.
When the headlamp main or dipped beam are on, is the sidelight also on? No.
2) Is the rear light on when the headlamp is on? No.
3) Are the instrument lights on when the headlight is on? No, only in park.
a) ignition switch off = no lights - correct
b) Ignition switch to first position - Parking lights - Sidelight bulb and rear light on, instrument lights also on (but not warning lights) - correct
c) Ignition switch to second position - Ignition on - Dip switch to dipped beam - Sidelight bulb, headlamp dipped beam (except when the starter button is pressed), rear light on, instrument light on (any applicable warning lamps on). - Nothing lights up, front, back or instrument cluster.
d) Ignition switch to second position - Ignition on - Dip switch to main beam - Sidelight bulb, headlamp main beam (except when the starter button is pressed), rear light on, instrument light on (any applicable warning lamps on). - Nothing lights up, front, back or instrument cluster.
e) Ignition switch to second position - Ignition on - Dip switch to flash - Sidelight bulb, headlamp main beam, rear light on, instrument light on (any applicable warning lamps on). - Only headlamp and 'high beam indicator' on dash light up.
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Fri Jun 26, 2020 5:18 pm
OK, I'm going to stick my neck out and say that the problem is in or around the lighting relay.
Are you able to check the voltages at the relay socket... there are five connections... with the relay disconnected they should read...
terminal 30 - (Red wire) battery voltage permanently
terminal 85 - (green wire)battery voltage with the ignition on
terminal 86 - (Black wire) ground except when the start button is pressed when it should read battery voltage (with ignition on)
terminals 87 (yellow/white wire) and 87b (grey wires) - readings not relevant at this stage...
With the relay connected
terminals 87 (yellow/white wire) and 87b (grey wires)- battery voltage with ignition on
Check that the relay clicks when the ignition is switched on and off.
The answers to these points should establish whether the relay is defective or the problem lies in the wiring up to the relay.
r75boxer
Postby r75boxer » Fri Jun 26, 2020 6:33 pm
Rob, I will work through your suggestions and get back to you tomorrow. Thanks again.
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
r75boxer
Postby r75boxer » Sat Jun 27, 2020 6:10 pm
Just to be sure that I am working with the right relay, see attached images (I've updated the photos). It's the last in a series of relays going towards the battery. Also, the wires feeding into the socket are as follows:
Grey/white (2), yellow/black, black, green/black, and red.
Relay 1 244 411 and 89 9675
Test results as follows:
Ignition off - power to 30 (red wire) was 12V. With ignition off, no other voltage detected.
Ignition on - power to 30 (12V). No other voltage detected in the socket.
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Sun Jun 28, 2020 8:45 am
OK, we're getting somewhere. First an apology. In my last there is a typo. I have swapped terminal 85 for 86. 86 should be green and should have battery voltage when the ignition is on. 85 should be black and be ground except when the button is pressed. I'm a bit surprised that your bike has a green/black there. The circuit diagrams show either solud green or green/violet. The significance is that green/black is normally a fused line. No matter though, if the fuse had blown, a lot of other things wouldn't work which do... It is always worth checking the fuses though.
That being said, the green should definitely get battery voltage so we need to chase why that isn't happening. That voltage is what energises the relay and without it, the symptoms you descripe make sense... The 1 244 411 is definitely the right relay.
The circuit to get voltage to the relay runs from the ignition switch to the multi connector for the left hand handlebar switchgear. On a euro spec bike it would go on up to the lighting switch but the US spec machine doesn't have a lighting switch so there should be a jumper of some description at the connector carrying the voltage across to the wire that goes to the lighting relay. I think this is the way to go...
1) get access to and disconnect the left hand switchgear connector. Use a meter to identify the wire that goes to the relay connector. If the wire is green black on the relay connector, then it'll probably be the same at the switch connector but bear in mind that the circuit diagrams show it as green or green/violet.
2) Identify the wire that goes to the ignition switch... this should be solid green. To be certain, test continuity using the meter. With the ignition switch connected, this wire should show battery voltage.
3) check to see if you can see a jumper between the two wires you identify above. The circuit diagram shows this as being in the wiring on the handlebar switch side of the connector block. If you can't see one, use your meter on the switch wiring to check if there is continuity between the two connections (no matter what the state of the switches).
4) If you still don't find connectivity, the next test is to replace the relay and use a temporary wire to short the two connections together (ignition on). There should be an audible click from the relay when the connection is made (The headlight won't light because the dip switch is disconnected).
5) If there isn't a click, you should check the relay is working. If you need instructions on how to do that let me know.
6) If there is a click, then the next step is to arrange a jumper between the two wires, that can be in place when the handlebar switch is connected. Once you've achieved this, with the relay in place and the switch connected, everything should be working correctly (heres hoping).
If as I surmise, the link in the handlebar switch wiring is missing, the permanent fix is simply to re-instate it... but that's making a lot of assumptions on what you may or may not find. Lert me know how you get on.
r75boxer
Postby r75boxer » Sun Jun 28, 2020 7:26 pm
Upon closer inspection the green/ is green/violet.
No connectivity.
At the switch: white to yellow and white to green show connectivity. See image. The green/black are horn (I believe) and blue/? are signals. The three wires hiding in the background/centre are (from top to bottom) green, yellow and white.
Did I answer this?
I need help here. How do I test that the relay is working?
Rob, I am including a few more images. First, the headlight pod has a mystery connector. Four wires: red, grey/black, green/black and brown.
The main bulb harness looks like this:
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Mon Jun 29, 2020 5:26 pm
Testing the Relay
It's important to test the relay clear of the bike so that you can be sure that the results are not affected by the surrounding wiring. You will need five pieces of wire which you can connect and disconnect at will, one load, a fairly powerful bulb is ideal, and access to your battery. You will need to connect wires to the bulb and to the relay. You can do this in a number of ways. I tend to use jumper leads with crocodile clips at each end and I keep a number for the purpose. You could also make up some leads with spade connectors to attach to the relay. For the bulb, you could remove an indicator, leaving the bulb still in the holder and make your connections to the bulbholder connectors.
Testing to see if the actuating coil works...
Connect a wire between the negative pole of your battery and terminal 85 on the relay. Connect a second wire to the positive pole on the battery and touch it momentarily to terminal 86 on the relay. The relay should make an audible click when you touch the terminal and another different click when you disconnect. This shows that the relay actuating coil is working... but, it doesn't prove that the contact are making - well - contact.
Testing the contacts...
leaving the arrangement above in place, connect an additional wire from the positive pole of the battery to terminal 30 on the relay. Connect another wire from terminal 87 to the bulb and a third from the other bulb terminal to the negative pole of the battery. Now touching the wire to terminal, 86 as mentioned above should cause the lamp to light. Finally, move the bulb wire from terminal 87 to 87b. Once again the bulb should light.
Carrying out these tests will confirm whethwr the relay is working correctly.
N.B. On no account attach a ground wire to terminal 87b while there are other wires connected to the relay (or preferably at all). This will damage the relay.
The handlebar switch
The green, green/black wires at the switchgear itself relate to the horn and to the main beam flash circuit, both of which work. They are not relevant for this exercise. You can forget the switchgear itself for the time being, the important thing is to work out why there is no supply to the relay terminal 86 and, in a US spec machine, that circuit doesn't go to the switchgear..
No, you haven't answered point 4... In point two, you should have identified the green and the green/violet wires in the left switchgear multi connector that go to the relay and the ignition switch respectively. These are not the only wires in the in the connector that are green or partly green so it is important to ensure that you identify the right wires. Once you have identified them, shorting them together with the relay in place and the ignition on should cause the relay to operate (click). As an additional check, you could try connecting the green/violet wire to battery positive, which should also cause the relay to operate (click)
The 'mystery connector' is the connector for OEM additional instruments... i.e. clock and voltmeter. Red + Brown for the clock, Green/black + Brown for the Voltmeter and grey/black + brown for the illumination lamps. There is an auxiliary loom available to connect from this connector to the OEM instruments.
The headlamp connector looks fine as long as the non-stock connector in the ground line (brown) is sound. I think we can assume it is otherwise the headlamp flasher wouldn't work.
r75boxer
Postby r75boxer » Mon Jun 29, 2020 10:25 pm
Testing the Relay
Yes, it makes an audible click and then another different one when removing the wire.
Yes, the lamp lights up.
Yes it does.
As shown in the image of the previous post I made showing the left switch, the middle three wires (green, yellow (I believe) and white. With ignition on and relay in place, when I short the green and yellow the headlight turns on (low beam). Distinctly different illumination from the 'flash' which I believe is the high beam. No audible 'click' when shorting or removing short. Does this mean the switch is not working?
Thanks also for the info on the mystery connector.
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Tue Jun 30, 2020 10:36 am
OK, well and good... the relay is in working order.... but we still need to find out why there is no voltage on terminal 86. Without it, the relay will do nothing.
In order to do this we need to know what is going on at the multi-connector for the left hand switchgear.
Your test involving the yellow wire in the switchgear itself of interest in that it proves that the wiring from the dip switch to the dip beam filament is good and confirms that the bulb earth is good but it has no relevance to why the relay isn't working.
We really do need to do tests at the multi plug to establish why there is no voltage on the green/violet wire that triggers the relay. The measures in points 2 to 4 will go along way to establishing this. but the tests must be done at the multiplug with it disconnected. For the purposes of this test, the switchgear is irrelevant.
We are not expecting the dip beam or main beam to light up, merely to establish why a good relay isn't doing what it should.
Once we've sorted that out, we can see if it solves the problem completely. If not we treat is as a new problem and start again.
r75boxer
Postby r75boxer » Tue Jun 30, 2020 10:35 pm
Thanks again Rob. We'll have to pick this up in two weeks - I'm off to the coast for some much needed R and R.
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Tue Jun 30, 2020 10:53 pm
Enjoy...
r75boxer
Postby r75boxer » Mon Jul 27, 2020 1:53 am
Hello all. I'm back from the coast and am aiming to get back into the R65 in a day or so. In the meantime, I'm going to post another query on an '83 R80RT that I just couldn't resist purchasing on my way back home.
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Mon Jul 27, 2020 10:06 am
Hi, Hope you had a good time. You'll find a '83 bike very different from your '87...
r75boxer
Postby r75boxer » Thu Jul 30, 2020 1:22 am
Rob, I spent part of this afternoon reviewing our discussions etc. and then decided to trace the G/V wire from terminal 86. It's a tough colour to actually see. If you recall, this bike was pretty much butchered before I got it - both the frame and certainly the multi-plug to the instrument cluster, as well as a number of connectors coming off the main loom and in the headlight pod. Well, I think I may have found two severed wires. See image. This is the first multi-connector at the front right side of the bike frame. The connector is red. When I checked for connectivity between the light relay and this plug I found the the wire on the far right connects to terminal 86. The one next to it, also severed, shows connectivity to terminals 87 and 85.
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Thu Jul 30, 2020 11:39 am
Hi Steve,
OK, this starts to make some sort of sense... first though, a word of caution. It's clear that this wiring has been seriously modified. Not knowing what changes were made could cause some issues as we proceed. Obviously the PO had a scheme in mind so look out for additional wiring and connections that could cause problems...
Moving on. I have looked at a spare wiring loom from by R80RT but the population of the terminals appears to be quite different. Can't be sure if this is because of the different bike spec or whether yours has been doctored but either way it doesn't really help.
In your image, I can see four wires (cut or otherwise). I can't see if position 1 (bottom right as you look at the picture) is populated but I don't think it matters.
The three wires we are interested in at the moment should be colour coded white, yellow and white/yellow. The last is very difficult to see. If my understanding of what is going on is correct, the uncut wire in position 3 (bottom centre on the image) is white. This would explain why the flasher works. This wire is the connection to the headlamp bulb main beam. The flasher part of the switch passes current from the green wire (Position 2) which is live from the ignition switch to the white main beam wire. The two cut wires should be yellow and white/yellow. If they are, they represent the connections to the headlamp bulb dipped beam and pin 87 on the relay respectively. It would be a good idea to test this theory before going too far.
1) Using you meter on the DC volts range, connect the negative probe to ground. Switch the ignition on and test for voltage on each of the cut wires (it may be easier to disconnect the plug and test the relevant connectors in the bike side of the circuit (the bit fitted to the bike). One of them should be at 12 volts, the other should be more or less zero. On inspection, the wire at 12 volts should be white/yellow.... I would expect this to be the top middle wire from your earlier tests.
2) Concentrating on the other cut wire, use a length of spare cable to connect this to battery positive (ignition switch position not relevant). this should see the headlamp dipped beam light up...
Assuning that the tests above pan out as expected, you now need to find the relevant wires in the handlebar switch. Looking at the image of the rear of the switch in an earlier post, they appear to be present at the switch so they must either have been cut in the loom or go somewhere else. If you can find them and re connect them to their relevant terminals, I'm hopeful that all will be as it should be.
My only question marks are over what has been done to the wiring by the PO. In particular, the configuration of wires in your red connector doesn't seem to bear any resemblance to any wiring diagram or wiring I have access to. I suspect interference with a number of wires. It doesn't help that both Haynes and Clymer diagrams are obviously wrong... they just don't make electrical sense... and neither of them, or the BMW diagram gives wiring positions in the multi plug.
Try the things above and see how you go. If things don't work out, please feel free to come back with details of what happened and we'll go on from there. I think we're gradually getting to the bottom of it :smile:. Working on wiring that has been 'modified' is always a bit of a lottery.
r75boxer
Postby r75boxer » Thu Jul 30, 2020 7:42 pm
Thanks for picking up on this again. My responses are below:
Yes, the 2 cut wires are yellow and white/yellow as best as I can see. The PO snipped them off right at the connector.
Yes, the wire closest to the frame showed 12v. A solid green wire feeds into this socket from the other side. The other (outside) reads zero.
Yes.
Further, I looked inside the harness from the switch side and nothing is visibly cut. On the connector end it appears as nothing has been spliced or diced. I then went to my box of bits from this bike and no wiring harnesses etc. were found. This doesn't mean that the PO didn't pitch them though.
I also checked connectivity between the yellow and white wires in the switch and they show connectivity to the same slots in the red connector. Nothing is missing in the switch - I don't think you could physically put another wire in the switch as it is plugged solid and everything is connected to something (if you get what I mean).
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Thu Jul 30, 2020 9:14 pm
Right,
Now we know the wires in the bike side of the connector are showing what we expect so the problem now comes down to working out what has happened to the yellow and yellow/white wires that were cut. They must have gone to the switch... all of the wires from the red and black connectors go to the switch.... as you say, the wires appear to be present at the switch end. If they don't appear at the connector end of the loom, then I can only surmise that they were cut and sealed inside the the loom tube. I'm afraid that will mean unwrapping the wires to see what has been done.
On the good side, I am quietly confident that, if we can reconnect the cut wires back where they should be on the switch, everything will work as it should... I hope.
r75boxer
Postby r75boxer » Thu Jul 30, 2020 9:46 pm
Rob, I peeled back the loom on both the red and black multi-connectors that feed into the larger plastic covered conduit which goes to the switch. Nothing is cut. The covering that I pulled off is clearly original and has not been tampered with. See attached image.
Is it possible that the wiring between the red multi-connector needs to connect to the relay directly? Are we looking in the wrong direction? As I said in a previous post, the white and yellow wires in the switch show connectivity to the red multi. What we aren't getting is power to terminal 86 on the light relay.
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Fri Jul 31, 2020 11:05 am
OK... moving on...
No, there shouldn't be any connections from the left handlebar switch outside the two multi connectors... although, if we realy get stuck, that's always an option.
In the new image I can see a yellow wire to the red connector which I couldn't see in the earlier picture it's probable, therefore that the yellow wire is sound... that means we are only looking for a yellow/white connection to the switch. There is also a question mark over the power to terminal 86 on tghe relay. Both of these connections go through the connectors to the left switch so it's logical to think (hope) that the issue is here...
1) we need to find the yellow/white wire to the switch. There has to be one... BMW always used a yellow/white wire for this function (at least as far as the wiring diagrams go) It's part of the ISO standard for vehicle wiring. The yellow/white wire is the wire that brings power from the relay to the dip switch... the switch then connects it either to yellow (dipped beam) or white (main beam) so without it, both the dipped beam and main beam can't work. Bearing in mind the anomalies to the red connector, can you check all of the other wires to both red and black connectors to see if there is a yellow/white wire in another position on either. Also check the rear of the connectors (red and black - attached to the bike) to see if there is a yellow/white wire there. If there is, what does it connect to on the switch side of the connector. Failing that, we are getting to the stage where we REALLY need to know what is going on at the switch. You should be able to see the wires at the switchgear. Looking at your image a few posts back, there should be 4 be 4 wires soldered to connections on a plastic plate in the middle of the switch. These should be (yes you guessed) Yellow, White, Yellow/White and Green. We can be pretty sure that white and green are there otherwise the flash wouldn't work. I now think the yellow wire may be in tact. it's the yellow/white we're interested in. There is an outside chance that a different coloured wire is there due to the work of a PO or an anomaly by BMW (unlikely) but we need to identify it in any case.If you can't see the wires, it may be necessary to dismantle the switch itself to check the soldered connections. This is perfectly do-able with care. If you need to do that, come back to me and I'll give detailed instructions. The object of the exercise is to find this wire and track it back to see where it goes. On my spare loom, it goes to pin 4 (middle upper) on the red connector which is one of the wires that is cut. This wire is necessary, without it, the lights will not work (other faults and anomalies notwithstanding).
2) That then leaves the issue of why we aren't getting power at terminal 86 on the relay. Looking again at the connectors to the left hand switchgear we want to identify a green wire which has 12 volts when the ignition is on. This seems likely to be the outside wire of the two cut wires on your red connector. we should also be looking for a green wire with a purple tracer. This is the same green wire with a purple tracer that goes to pin 86. Once these have been identified, you need to arrange a permanent link between the two. In the original set up, this link happens in the loom between the red connector and the left switchgear... these wires (on a US spec bike) don't go to the switchgear itself. You can make the connection in any way you like... probably at the connector would be easiest.
Hopefully, if we can resolve these two issues we'll be getting close to getting it working as it should...
r75boxer
Postby r75boxer » Fri Jul 31, 2020 3:21 pm
In answer to your questions:
1) There is a yellow/white going to the switch and this wire has connectivity to the black plug (upper right i.e. outside) and this has a y/w to terminal 87 on the relay. I get connectivity along the entire route.
2) As before, on the red multi there is a green wire that connects to the inside top of one of the cut wires. 12v with ignition on. The green/purple has no voltage (upper outside of red multi).
So, are you suggesting that I make a connection b/w the 2 cut wires on the red connector, or has my coffee not kicked in yet?
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Fri Jul 31, 2020 9:07 pm
Yes, that's exactly right. I suggest you make a temporary link first just in case but it looks like that's where the problem lies. It also looks like someone has been moving the connectors around in the two multi plugs. The yellow/white should be in the red plug along with the yellow and the white but unless you're going to be replacing the handlebar switch, it won't matter. Make the link and let me know what happens...
r75boxer
Postby r75boxer » Sat Aug 01, 2020 2:15 am
Bingo! It works. Thank you very much for helping me with this Rob. If I'm ever in Scotland, or you're in western Canada, I'm buying .... a pint, or 2, or 3.
Kevin
'02 R1150RS
'87 R65
'71 R75/5
'58 R26
'51 R67
Postby Rob Frankhamr » Sat Aug 01, 2020 9:40 am
Really glad we got there in the end... it would be great to share a pint if we're ever in the same part of the world at the same time... ride and enjoy.
Now to the 'RT :???:
Postby Mjolinor » Sat Aug 01, 2020 12:00 pm
Have to say: Totally impressed with this thread. I stayed out of it and wondered if it would get resolved. Really good input from both parties for a resolution.
Users browsing this forum: No registered users and 20 guests
