Rear Brake Bush fitting
jtreg
Postby jtreg » Sat Apr 04, 2020 4:26 pm
Hello there,
Going through my R80RT (1983) as it has been laid up for over a year...
I changed the rear brake switch as it had failed. The problem now is the rear brake is really sloppy and will not line up accurately (on and off) and I found the read brake pivot bush is completely worn. I am reluctant to use heat on the frame to remove it and fit the new one. Any tips on fitting the new one? It should arrive next week hopefully.
Anyone done this little job?
Cheers
James
2010 GS Adventure 30th Anniversary Edition NICKED. Now 2010 Yamaha XT660 Tenere!
1995 R1100RS (still in the family now owned by my son)
1983 R80RTIC
jtreg
Re: Rear Brake Bush fitting
Postby jtreg » Sat Apr 04, 2020 6:36 pm
Happy to report that with the correct pinpunch (big un) , Plus Gas and some hot air gun it drifted out. I was a bit reluctant to mess up the fram but its OK. I will freeze the new bush before putting it in. - Anything anyone would like to add?
1983 R80RTIC
jtreg
Postby jtreg » Wed Apr 08, 2020 11:48 am
Motobins supplied the OEM part - sadly it was too large inner diameter - returned and I scratched my head a bit then measured the bolt and outer diameter etc and hit the interwebs. Bless the company http://www.getyourbearings.co.uk/ - they emailed me to say the £1.32 part was on its way... (Hint: try them for consumables before the 'usual' channels'!)
Signing off but not out
James
1983 R80RTIC
