Mobile phone GPS on an R100RS
vmx1200
Postby vmx1200 » Sun Jun 28, 2020 5:39 pm
This may be of no interest to anyone but I thought I would share it if it helps even one person searching on the web!!
Last year I saw a waterproof mobile phone case fitted to one of our club member’s bikes which he used as a sat nav in conjunction with Bluetooth earbuds. I thought this might be useful as I had never been able to justify the cost of a pukka motorcycle GPS as I am not into touring.
When my daughters asked what I wanted for Christmas I gave then the details of
Ultimateaddons UNIVERSAL WATERPROOF CASE FOR SMARTPHONE UP TO 160MM
https://ultimateaddons.com/collections/ ... proof-case
25MM TO 3 PRONG ADAPTER V2 WITH PUSH BUTTON
https://ultimateaddons.com/collections/ ... sh-buttons
The case is very well made but huge but so many mobiles are huge these days
This all fitted and worked well on the nine T in conjunction with a standard RAM ball mount however I could never work out a way of fitting the case to the RS and having searched the web for Sat Nav / GPS on an RS found very few examples many of which seemed rather Heath Robinson.
A few days ago I saw a bicycle fitted with a bar clamp for one of this make of products so decided to try one £16 with free return
https://ultimateaddons.com/collections/ ... nt-19-33mm
It only takes a few minutes to fit (2 screws) and remove after the crash pad is removed which of course can be refitted when the mount is removed.
The case is firmly held, I can still get to the switches, so am happy with this solution
1978 R100RS owned since 1981
2017 R Nine T Pure
Re: Mobile phone GPS on an R100RS
Postby george baker » Sun Jun 28, 2020 10:24 pm
What app are you using?
Postby windmill john » Mon Jun 29, 2020 7:27 am
I got a more basic one from them but works fine:
https://ultimateaddons.com/products/gps ... 4816116747
George, I’ve used Michelin maps and Google maps. Maps.me was very good, then stopped on my phone for a while.
It’s important to note in my cases, I’ve only used it and the apps a few times as I’ve not been abroad for a while.
Postby george baker » Mon Jun 29, 2020 10:58 am
ta John
Postby george baker » Mon Jun 29, 2020 11:06 am
ta John
vmx1200
Postby vmx1200 » Mon Jun 29, 2020 11:33 am
Hi George
I use Google maps and for the times there is no mobile phone signal I have a download of southern England (which updates itself when on WiFi) on the phone.
I also rum TomTom Amigo which is their free navigation app and has better speed camera ability than Google maps but only works with a mobile data signal
2017 R Nine T Pure
Postby george baker » Mon Jun 29, 2020 9:55 pm
Hi 1200
Do you mean I just download a google map and then my mobile phone just leads me to my destination like a sat nav if I don't have a 4 g signal?
Postby Mjolinor » Mon Jun 29, 2020 11:02 pm
Google made the changes not too long ago that allowed oyu to download specific maps and then you can use it as a sat nav. It is a bit fiddly as you cannot download all the maps I don't think. You have to select where you want the maps for so if you don't do it right you get half way to your destination then run out of map. :)
Postby Rob Frankhamr » Tue Jun 30, 2020 11:00 am
I used to ise an app called 'Don't Panic' (relevance anybody???) which is/was a fully featured sat nav. I've also used Maps.Me and the succesor to 'don't panic' called 'Genius Maps'. All of these are downloads onto an android phone (don't know about I-phone but I expect they work there as well) and, while they don't have all of the whistles and bells of the dedicated unit, they are easy to use, effective and accurate. The benefits are...
1) You don't have to buy a dedicated (and expensive) piece of equipment.
2) You only need one bluetooth connection.
3) The output from the Sat Nav will overide media and/phone conversations... or not if you don't want it to.
The disadvantages... well, if you ignore the aforementioned whistles and bells, there are no disadvantages.
I have to say, though, that I am increasingly impressed by Google Maps for this use. It's quite useable and much more up to date in terms of actual road conditions than anything else I've used.
vmx1200
Postby vmx1200 » Tue Jun 30, 2020 11:02 am
Hi George
As Mjolinor said you are not downloading the route but also the map itself so you can continue to navigate with no mobile signal, obviously you will not get any traffic info etc when off line,this all happens seamlessly
You can select the map area for you chosen route or a larger area if want one you have the map download the route planner will use it if there is no signal, of course the map can be a large file )it can be saved to SD card)
Here is a link to the instructions
https://support.google.com/maps/answer/ ... roid&hl=en
2017 R Nine T Pure
Postby Mjolinor » Tue Jun 30, 2020 12:03 pm
I specifically bought a Blackview BV6000 when this became do-able.
Waterproof, shockproof cheap phone. I would recommend them to anyone with the only downside being that the USB was a long way up a hole so finding charge cables was difficult and my thermal camera could not be used with it. Also not possible to retain the waterproofness (<< is that a word?) if you needed to charge it.
Postby Rob Frankhamr » Tue Jun 30, 2020 12:17 pm
Waterproofity perhaps :drunken:
IanG
Postby IanG » Thu Jul 02, 2020 8:13 am
I use a Sat Nav on my mobile called Waze which is really good. Google took them over a while ago, which is why Google maps has got better at navigation as they are using some of Waze's technology. So far they haven't interfered much and let Waze stay independent. I don't use a Sat Nav often on the bike but when I do I just use the voice directions through my helmet intercom with my phone in my pocket. I think looking down at the screen of a mobile phone could/would be pretty distracting and voice only works fine for me. Because the screen isn't on, the battery on the phone isn't impacted badly by the Sat Nav either.
Ian
1983 R100
1955 Norton ES2
1972 Norton Commando
2001 Honda VFR800
19** Understanding wife
andymcg
Postby andymcg » Sat Jul 11, 2020 11:57 pm
Ian
I use Scenic as a motorcycle sat nav app on my iPhone.
It works well with phone in an ultimate add ons case.
The scenic app shows your speed and it records the route so you can see where you went and sync it to PC etc.
Gives average and max speed and can produce a shareable file of the route.
It does make it harder to justify a dedicated bike sat nav,
I have RAM mount ( or eBay copies) balls on each bike and can swap the case onto whichever I am riding.
For power I have a 12v to USB power lead that plugs into the accessory socket.
Only weak point is that it can be hard to use touch screen with glove on. Removing glove to text while riding is frowned on!
Christmas & birthday brought me a SCHUBERTH C3.basic helmet then their Sc10 Bluetooth communications fit. It is very good and I can listen to the voice instructions or stream anything from the phone.
Not sure if being able to use mobile hands free while riding is useful or not.
Sometimes one rides to get away from normal life!
It's not grim up North!
since 1994 a R100R and from Oct 2015 "Walter" K75S, and from Aug 2016 R850R!
Postby george baker » Sun Jul 12, 2020 11:29 am
'Removing glove while riding is frowned on!" Cos i always hurts me too much when I damage my hands . And they get cold
Postby CharlieVictor » Sun Jul 12, 2020 3:15 pm
Ian
French VTC (limo) and express courier drivers favorite app, it's based on live data uploaded by the users to determine an alternate (sometimes very convoluted) itinerary.
1999 650RS W3 Replica "Twin With a Kick"
