K&N oil filter - which model?
nikon70
Postby nikon70 » Fri Apr 26, 2019 11:18 am
I’ve just ordered a KN-160 but I think I ordered the wrong one...
Does the KN-160 fit or do I need the KN-164?
Re: K&N oil filter - which model?
Postby george baker » Fri Apr 26, 2019 11:39 am
which bike?
nikon70
Postby nikon70 » Fri Apr 26, 2019 12:52 pm
R1200RT 2009
Postby milleplod » Fri Apr 26, 2019 1:16 pm
I reckon you need the shorter one, the 164.
Nocto Diuque Venamur
nikon70
Postby nikon70 » Fri Apr 26, 2019 2:59 pm
Damn it! Thought as much, was hoping someone was going to reply saying they use the KN-160 with no issues
Postby Jaythro » Fri Apr 26, 2019 3:06 pm
Why buy those filters????
Mahle original manufacturer for the BMW Part number OC306 and If you can order an OC 306D you get the crush washers too!
https://catalog.mahle-aftermarket.com/g ... 48#divider
Postby milleplod » Fri Apr 26, 2019 3:11 pm
It'll probably fit, although I would personally want the correct one on my bike! Oh, if you stick with K&N, don't use the nut attachment when fitting the filter, it's only for removal - lots of reports of metal failure around the nut, and it seems that the issue is where the filter's been over-tightened when fitting....with that very handy nut! Hand-tight is more than enough. :smile:
As an aside, I only ever use BMW filters, Knecht-Mahle (who make the filters for BMW) or Mann.
Postby milleplod » Fri Apr 26, 2019 3:12 pm
Yup! :grin:
nikon70
Postby nikon70 » Fri Apr 26, 2019 3:29 pm
Ok ordered the OC306
I already have crush washers
I just defaulted to K&N always have done on my Honda and Suzuki bikes and always hand tightened with a little oil around the seal after filling the oil filter with oil too.
But if the consensus is the 306 then that’s what I’ll go with.
