rear swing arm gaiter
pmage2
Country of Residence: wales
Postby pmage2 » Sun May 10, 2020 11:06 am
Hi all replacing the rear brake disc on my k1200 (2000 reg) took the disc of and the gaiter is split is it much of a job to replace the gaiter yours paul.
krankshaft
Re: rear swing arm gaiter
Postby krankshaft » Thu May 14, 2020 5:42 pm
Hi, pmage2
I think the reason you're not getting any response is because the question is a bit vague, it is also a matter of
opinion if it is much of a job or not, depending on your skill level and access to tools and workspace.
I think your best bet is to read through the procedure of swing arm removal in your manual, (Haynes or Clymber)
and see what you think yourself as regards skills/tools required.
Hope this helps
Ride safe
Jim
